That makes sense, but alternatives of starting coasting earlier, or using engine breaking to slow down, would probably yield better results (if you stay in a moderate gear in relation to your speed and can DFCO most of the way to the stop you use LESS fuel on the journey from where you are to stopped-at-the-stop-sign).
