Old 11-11-2008, 01:48 PM   #3 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Hi Z33ky - welcome to the site.
Preface: I'm not sure if the XFi motor's compression is different (it could be slightly higher, owing to different valve timing/lift/duration).
The spec on my '98 garden variety engine is 199 PSI @ 250 RPM according to the factory service manual.
Minimum allowable compression pressure is 156.4 psi @ 250 RPM
Important: the maximum allowable compression pressure difference between any two cylinders is 14.2 psi @ 250 RPM
