Thanks for the great responses and kind generosity!
Below is a photo of what I think is the 'factory plug' or 'timing connector' (correct me if I'm wrong) and according to the Chilton's manual I need a 'fused jumper wire' to jump 2 of the pins located in this connector and I see the diagram under the hood where to connector the fused jumper wire (the lower left & lower center pins). Should I purchase a 'fused jumper wire' or just make one and if I make one what kind of fuse should I use?
Excellent job on that 1.0L Head Repair Guide Johnny and thanks for all the work and effort that went into making it!
I failed to mention in my initial post that the wheels were not stock but are 13" wheels.
