I was thinking about doing the rear as well, but the front ones were a priority, especially since I had to get them back in the car just to use it again!
I also bought a "water pipe heater" at the store, but it has a built-in thermostat, which makes it not turn on unless the sensor hits 38 degrees F or less.
I am planning on returning it to the store, because I can't see a good way to just remove the thermostat without wrecking the thing.
