Originally Posted by bennelson
A couple summers ago, I got to drive a Solectria Force Geo Metro conversion. The body was that of an automatic transmission. I don't recall exactly what it had for a transmission in it.
What do you mean the body was that of an automatic? You mean it was a sedan?
As far as I know, the Solectrias had a single speed custom transaxle. Don't need gears with a 12 or 14k RPM AC motor.
What is required for an automatic transmission to run?
Assuming it's old school, you just have to turn the input shaft to build up fluid pressure. More modern computerized transmissions need all kinds of sensor & ECU input to work well. (Not an issue with the Metro).
Could this be a decent EV conversion?
Auto EV's have been done. There's an automatic Metro sedan conversion under way on YouTube:
Personally I don't like the idea of a conventional automatic in an EV. Even if it only costs you a 5% efficiency loss, that's too much. :P
