Old 11-13-2008, 02:13 PM   #4 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
Drat! I was planning to mock up a cardboard Kammback on my dad's Corolla and ABA test it on the road this fall, but I ran out of time. I was hoping it would encourage someone in the sedan fleet to take the plunge.
But, yay! You're taking the plunge.
Thoughts:
1) That black & white picture is by far the coolest;
2) You shouldn't have dew problems to solve on the OEM rear glass if it's shaded by the Kammback;
3) Definitely consider lexan/clear for part of the top portion if the horizon as viewed through your inside rearview mirror is higher than the lowest point of the Kammback;
4) Don't leave anything on the table by just following the existing side curvature; I'd change "potential" plan taper to "definite" That will put "shoulders" in the design, complicating construction, aesthetics & clearance for opening the trunk, but it's likely worth doing.
5) I'm just WAGging, but I'd say fences would be less effective than just going with a very generous radius at the top/side transition.
Are you planning to enclose the transom, or leave it open?
