Thread: Good Timing
Old 11-13-2008, 11:16 PM   #1 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Good Timing
No, not "at the right place at the right time", but spark timing instead
I performed a full-advance over the summer and didn't have much of a problem with detonation (but a decent bump in FE) and improved low-RPM efficiency.
Now, loads are bit higher (likely due to the colder weather, and the varied resistance from a variety of operating sources -- rolling, viscous, wind, etc.) I hear pinging quite often these days -- so what to do?
- Retard the timing a bit
- Wait for colder weather
- Change the Oil, it's due
- Run 89 Octane (at 10-cents more/gallon, it would only be about $1 every 2-weeks)
The latter has been on my mind -- is the FE bump worth a buck or 2? ...Or is there option "E"?
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
