Old 11-14-2008, 01:14 PM   #21 (permalink)
trebuchet03
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Originally Posted by Bicycle Bob View Post
I'd try to copy the slope of the rear window on the Prius, more or less. The steeper and longer you can make it, the smaller the wake from the kamm back. Provided it is not so steep that you get separation, which will depend on how much turbulence is generated farther forward. It might be worth leaving the new rear window adjustable for a few runs to find the sweet spot. A kamm back is not a substitute for a long tapered tail, it is just a better compromise than a short taper or rounded tail.
I'm going to try two things...
First, I'm going to connect the roof line with the trailing edge of the trunk.
Second, follow the Prius curvature no matter what.
After that, I'm moving on to the 3D model... Computing time will be much higher, but I'll get results that are more reasonable.
Challenge me, or correct me, but don't ask me to die quietly.
