Thread: Good Timing
Old 11-14-2008, 02:14 PM   #4 (permalink)
some_other_dave
How much of an FE bump did you see from advancing the timing? If the percentage is less than the percentage difference between regular and mid-grade, you're better off retarding the timing back to stock specs and running regular.
And if the oil change is actually due, do it either way!
-soD
