Old 11-14-2008, 03:14 PM   #6 (permalink)
IndyIan
EcoModding Newbie
Parachute - '03 Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Neon Highline baby!
90 day: 31.39 mpg (US)
Stihl has chainsaws with spring starters, you pull the cord winding up the spring and when its fully coiled it releases turning over the engine. I've played around with one in the showroom and it seemed to work quite well. I don't know if it incorporates an auto decompression system as well.
It doesn't add much weight or bulk either.
Although springs don't store as much energy as batteries they sure can release it quicker! A typical spring on a strut seems to have enough energy to turn over an engine a few revolutions faster than most starters. The trick is harnessing it and reloading it.
Maybe for 1.0L engines all you need is to fit decompression valves to all the cylinders and then use a kick start off a motor bike.
Ian
