uberhho -
Originally Posted by uberhho
If you are getting the magic 14.7:1 then I would see no need to do any more trick f&*$ing my friend. Now my question is are you seeing any improvements, if not why?
I have stopped using it because I want to make sure that I comply with emissions (hence my desire for an affordable NOx sensor in post #5).
In terms of improvement, I have theorized that the
SG does not use the 02 sensor output for calculating MPG. Now that you ask, I think that proving this would be a job for the
MPGuino.
CarloSW2
