Old 11-17-2008, 06:50 PM   #7 (permalink)
TestDrive
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Originally Posted by Duffman View Post
If you understand all this than it will be simple to build and you wont find a cheaper way I dont think. You will need a transistor on your output to power your relay.
Thanks for the thought, but it's all greek to me.
Originally Posted by trebuchet03 View Post
If you can solder, the kit goes together in a few minutes (at least for me) - aquick google search, and I found a place selling the same timer I used Adjustable Interval Timer MK111 - VETCO.NET
That's how I'd do it cheaply...
Thanks. Not exactly what I want, but close enough - I'll probably order the kit.
Spec. for the kit is
  • output relay with dry switch-over contact: 3A/24V
  • pulse time adjustable: between 0.5 and 5 sec. (0.2 sec - 2 would be better.)
  • pause time adjustable: between 2.5 and 60 sec. (1.0 - 6 sec or more would be better)
  • power supply: 12V DC / 100mA
  • dimensions: 1.6" x 3.4"
