Thread: Good Timing
Old 11-18-2008, 01:33 AM   #9 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
So, how much grille block is too much?
It was relatively warm today (45F). With a double grille block (block the A/C rad up front, and a cardboard piece sandwiched in front of the coolant radiator). Driving in-town or on the highway, the fans kick on and temps rise and level to 210F reported (likely 195-200F at the thermostat).
It's the most aggressive grille block I've tried. Warmups are much quicker and efficient IATs are available sooner. I filled with a higher octane fuel for the higher temps and the knock. Hopefully, the Winter temps will allow normal operation.
Any advice? Pull the power to the fans, pull the cardboard? Wait for the cold?
-Rick
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
