Old 01-28-2008, 08:37 PM   #17 (permalink)
TomO
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
What's the wattage again? (Sorry, being lazy - I know you mentioned it in your installation thread.)
400Watts
I wonder if a better measure for comparison's sake might be the weight of the engine. The Suzuki 1.0L mill weighs about 135 lbs.
This makes me think even more....does the firefly have an iron block and aluminum head? That 135 lbs. for a 1L 3 cylinder motor is really heavy! IIRC the 1.5L block in my VX weighs in at ~140 lbs. The block and head are aluminum with an iron sleeve pressed into the aluminum for the combustion chambers. Open block design as well.
It might not be a very measurable difference for the thermal conductance between iron and aluminum blocks especially when you have coolant in the mix as well.
Oh, Oh, just found some info:
Thermal conductivity of pure aluminum:
  • Temp 68°F = 118 (Btu/(hr oF ft2/ft))
  • Temp 200°F = 124 (Btu/(hr oF ft2/ft))
  • Temp 400°F = 144 (Btu/(hr oF ft2/ft))
Thermal conductivity of Cast Iron, gray:
  • Temp 70°F = 27-46 (Btu/(hr oF ft2/ft))
Thermal conductivity of Iron, nodular pearlitic:
  • Temp 212°F = 18 (Btu/(hr oF ft2/ft))
Seems strange that they aren't really comparing the metals at the same temperature. I got the info from HERE.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
