Old 11-18-2008, 09:53 PM   #2 (permalink)
Whoops
Whoop's Wheels - '89 Civic Wagovan
90 day: 39.09 mpg (US)
With it being a 94, unless you don't have any other choice, I'd scrap that and go buy something to replace it. By the time you get any work done on it by a body shop, your going to have more money into it than it will be worth.
If you don't have any other choice, you could get by, just fine, by removing the hood, grill, drivers fender, radiator. Then you can probably just move the front support back out enough, with a scissor jack between the support and the front strut. You don't have to get that support back to perfect shape, you just need to get it moved back out enough to get a replacement fender, hood, grill and radiator to align so it can be attached. Of course this presumes that it is not busted loose, or broken. If it is, you can braze it in, most likely and it will be fine.
Good luck with it, or whatever you do.
