random fact about my transmission: With the car off, not moving, I can put the transmission in any gear and it will do nothing. IE on a hill it just rolls away. Now that's a static drop. I've also turned the engine off while traveling at slow speeds, as the engine output shaft drives the trans coolant pump. High speeds off not recommended by manufacture and aficionados alike. I've yet to muster the will to turn the car off while in any gear traveling at any speed. I don't think it'd end well, and I have no capital to find out.
