Old 11-21-2008, 10:15 AM   #84 (permalink)
trebuchet03
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Following the information a book titled "Road Vehicle Aerodynamics" by Scibor-Rylski - I modeled a ground effect approximation. Downside is, it doesn't take into account viscous losses and I can no longer measure lift. What you don't see in that image is the bottom half of the model, which is a mirror image. Plane 3is the virtual ground - 14 inches below the vehicle.
Why? I don't have enough memory to run even a 2D ground plane... Bugger... At low resolution, I can make it
So I've added an engine approximation thing and a radiator. The radiator is a bunch of squares (40, I think) offset from each other by about a half inch. I added my two grille openings and an outlet vent on the top (which is a bit too big methinks).
According to Scibor-Rylski - internal losses account for about 12% of total aerodrag with gains to be had up to 6%. Mind you, this book is a bit dated
Is this model right? I lean towards "no." My tuft testing showed fairly steady flow the entire length of the hood. BUT, light yarn doesn't need much velocity to show a flow direction. This could very well be what's happening, but I'm not entirely convinced just yet. I'm going to measure my grille's and modify.
Challenge me, or correct me, but don't ask me to die quietly.
