Old 11-21-2008, 12:01 PM   #7 (permalink)
Unforgiven
Impala - '04 Impala base
90 day: 29.81 mpg (US)
Yeah, sadly the initial look at the two transmissions side by side (4t65e vs 6t70/75) show a bolt pattern difference (which should be adaptable with the right plate and extention for the input shaft) but the mounts, size and many other differences would make this a difficult at best swap. Still have to research things more and get physical dimensions and such to make the final decision. Supposedly the 4t65e I have has a 4th gear ratio of .70 while I see CFG83 found info suggesting a 6th gear ratio of .742... which would actually increase my engine rpm in that gear...hmmmm. LOL pros and cons...
Had not found a 4th gear swap for my trans yet, although I would hope one is available. Did find a link in lazy browsing yesterday that showed some performance transmissions of my type... ah well.
Thanks once again for the info you folks are helping me find!!
