Old 11-21-2008, 03:00 PM   #11 (permalink)
Fast Guy
Originally Posted by wyatt View Post
A couple things I see that could help fuel economy by improving your aerodynamics would be:
1. An bellypan for under your engine. ........
2. I don't know how vital your huge "mouth" opening is......
There's a small plastic undertray already, but I think I'd prefer to replace it with something better eventually.
The opening is pretty important if I don't want to melt my pistons. The radiator is behind the intercooler and both are vital to engine cooling and therefore engine life.
Originally Posted by Christ View Post
OP, when you're not racing, you could certainly cover that up though. Unless you rev high all the time. Your Turbo shouldn't even really be spooling in street driving, so it's not really heating up enough to utilize an intercooler that much.
I rev high alot of the time Motorway cruising is when I tend not to use the boost.(you sort of get adicted to the acceleration)
Originally Posted by rav View Post
The mirrors are awesome, where did you get them from?
Ravi
I got them from here. Although quoted for my car, the base plates are wrong and so need modifying slightly to fit.
- ESP Design Ltd
Originally Posted by dichotomous View Post
do you have tunable engine management with boost control? thats how you could get some great numbers, tweaking the exact fuel shot into each cyl for each throttle input % and rpm and boost level, and keeping boost to about 1psi or so would help so that there is no "suck" portion of "suck-squish-bang-blow"
At the moment the standard ECU is looking after everything. Standalone management is further down my list as the one I want will be about 3-4000$ depending on options
