Old 11-20-2008, 12:02 AM   #1 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Can swapping in taller gearing result in worse fuel economy?
NOTE from Darin: This thread calved off from Which mass produced car is closest to a teardrop shape ?
Keep in mind that reducing gearing is not always the answer either. I can personally vouch for this.
I once mated a CRX HF transmission to a slightly modded 1.5 liter engine... I LOST even baseline efficiency, to the extent of going from 40MPG down to 21 MPG.
I started researching how this could happen... to find that:
the CRX HF gets its' max torque at something like 1800-2000 RPM... meaning that doing 70 in 5th gear puts it in it's max efficiency area (area of peak torque)
Putting that same transmission against an engine that makes considerably less torque in that area will not gain net efficiency... you will lose it.
Please keep that in mind when choosing gearing.
This is the reason that most Honda transmissions place cruising speed at close to 3k RPM... it's where max torque usually is in those engines. It's also key for efficiency.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
