Old 11-22-2008, 11:07 AM   #19 (permalink)
fanamingo
fanamingo's Avatar
Originally Posted by KJSatz View Post
On a ScanGauge or the like ... monitoring the MAP sensor will tell you (it jumps down if you're in and jumps up if you're out).
KJSatz, can you elaborate on the output of the MAP sensor (typical values)? I had tried monitoring it a few months ago, but was never able to see a distinct jump that would show when i-VTEC was engaged/disengaged.
