Thread: MPGuino problem
Old 11-22-2008, 10:17 PM   #1 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
MPGuino problem (fixed)
Ordered a kit version MPGuino a month ago, it came in Thursday and put it together last night. Today I tried installing it. I wired it up to the wiring off the ecm and plugged it in and it came right up working. I started the car and it was showing the injector signal was working fine. As soon as I started to move the car it reset. So I turned it off and rechecked my wires and everything is properly wired up. I took the easy way out and jacked a wheel up so I could spin the tire in the garage. Any time I spin the tire and it gets a vss tick it resets or locks up. I messed with it for a few minutes before it corrupted the avr chip. So I gave up since it was getting cold out.
I had to reload the avr completely, it scrambled the bootloader even. Not a big deal I have everything I could need to work with Atmel chips. I am getting ready to figure this thing out. Other than checking the vss signal path is there any other ideas anyone has for stuff to check on?
My Convertible Metro XFI Plug in Hybrid Project build log
