Old 11-23-2008, 06:19 PM   #4 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Good update, Ken.
Get yourself a good block heater and stop idling! It'll probably save you as much fuel as the transmission swap will, plus it's nicer for the engine.
Also: note that after the swap, you'll have to do a correction to your odometer readings to calculate MPG on a level playing field. The speedo gear in that transmission will likely be different from the one in the original tranny.
So, before you do the swap, do a very precise measurement of Point A to Point B with the current transmission so you can repeat it and figure out the difference after the swap.
