Old 11-24-2008, 02:13 PM   #112 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I'm on SW08 atm which doesn't take advantage of multiple cores sadly. 09 takes advantage of multiple cores for boolean operations and a few other things like opening multiple files. They're slowly converting it over to work with multiple cores. Recommendations from our reseller say to stick with dual core unless doing FEA since there isn't a huge advantage and single cores really aren't getting THAT much faster for the buck.
BTW, you can go into the bios and deactivate hyperthreading and you should see a performance boost in SW. But, I think Cosmos should take advantage of it.
