BTW, how are you running out of ram? You should be able to increase your swap file size to accommodate as much as winXP 32 can handle. It just gets incredibly slow as it has to access the hard drive so much.
Another thing to search for is the "3 gig switch" in XP. Its a registry hack that alters how much virtual memory XP allocates to itself out of the four gig max. If you are literally running out of memory that XP can handle, the 3 gig switch will help.
