Old 01-30-2008, 12:14 AM   #6 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
What kind of performance are you going to be looking for? What are your minimum acceptable range & speed goals?
My suggestion: think about doing a 72 volt conversion. That will permit you to use a series/parallel setup with the 36v forklift controller for smooth, lower speeds @ 36v (2 strings of 36v in parallel mode), and switch to 72v (2 strings in series) for speed.
It'll also let you use your 36v charger - you can charge both strings in the pack in parallel mode.
Very exciting.
