This cord is all white and there are no colours visible but from the instructions for the wiring on spiffie the male end looks like this. facing the contacts, cord towards you,
this is the female to board config:12V-, 12V+, injector, VSS
this is the cord: VSS, Injector,12V+,12V-
I'ts easy to fix by swapping wires but the instructions should be right.
I'll test the cord later to see if it's crossing over. I did come with my mac for using the fax function although I've never heard of one.
