Old 11-27-2008, 09:36 AM   #26 (permalink)
theunchosen
If you are really looking to gain HP/MPG like as is said above the best method without touching the engine is to take the pipes run 4-1 then say3-4 feet from the engine total length of pipe chop them off.
Most cars that do this angle the exhaust to the passenger side(although if your exhaust ports are closer to driver side then thats adviseable) so it doesn't muck-up the underside of their car with soot. They manufacture vents that go onto the side(on the fender behind the wheels) so that the gases clear the car and avoid getting exhaust all over your paint. Although. . .the gases are accelerating for 18 inches outside the engine so, its safe to say as long as the pipe gets to the edge of the car the gases will clear your profile if the pipes are only 3-4 feet long.
