Old 11-27-2008, 02:28 PM   #29 (permalink)
Vince-HX
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
Last 3: 58.02 mpg (US)
imo all of honda's engines are performance engines, even our despised SOHCs
jdm d15b 3 stage vtec = 87 hp per liter N/A
And that engine also utilizes vtec-e and has the ability to be tuned to lean burn for afr's around 22-25:1 low load cruising for uber economy
If you want power you need to have forced induction, I/H/E aren't even worth it for n/a imo. Why spend all that money for maybe 25hp when for about the same price you can piece together a turbo setup that will double your stock number while upping the overall efficiency of your engine and allowing you to run longer gears.
And stock d series rods are fine to 250whp
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
