A set of snap ring grooves cut on the input spline of the tranny will hold the coupler in place. I could do it at home with a home made fixture but you absolutely need a sharp corner on the botton of the groove to make it work. If you do it with a set screw, be sure to drill a dimple in the input shaft so it will not work loose due to slight misalignment. Locktite it!
Do you still need a clutch hub??? I am looking thru my pile of spares...
