Old 11-28-2008, 01:57 PM   #3 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
I usually check pressures, but didn't this time -- it was busy around the airport due to the Holiday. But as always, further testing is required to get a good data set.
I filled twice -- the higher-speed tank was 29.x and the speed-limit run was 31.x. I usually use the second tank as a good barometer since I know it's full. A variety of factors could be at work...
Interesting with the 50-Litre Challenge Corolla. I've driven the '09 Sedan a couple of times with great results (high 30's), but this 5-door setup was different enough to drag it down somehow. Hopefully I'll drive another one and see what happens (with a bit more attention to details).
It's still a nice vehicle -- I hope it's just a fluke.
-Rick
Interesting. That drop in mileage could be from a number of factors of course. (Do you check tire pressure for each rental?)
Remember the Canadian "50 Litre Challenge" fuel economy run? The Corolla automatic - same drivetrain as this Vibe, if I'm not mistaken - pulled good numbers:
Hard to compare, of course, and very likely a slower average speed than you recorded.
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
