Originally Posted by Offspring
dude, i thought this forum was about saving as much weight as possible. thats way too much weight for 3 ozs . if your putting 3 oz's in thats because you have one hell of a bent wheel. some need that much but the majority dont.
and if you dont like the hammer on wheel weights cause you think they look like ****, just ask the tire guy you would prefer if it was balanced using stick on wheel weights.
Yep, I get them as close to zero balance as possible, if they're w/in a .25oz, I don't worry about them... if they need more than .25oz, It gets sticky weights.
The only problem with sticky weights is that they fall off sometimes.
