Old 01-30-2008, 05:19 PM   #531 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
The charger didn't automatically shut off last night. This is the first time this has happened since I repaired it a few months back.
Recall that I'm charging the 48v pack with a 24v charger by splitting it (the pack) into two strings and paralleling them.
I checked each battery's voltage under charge, and two (one in each string) weren't coming up enough to trigger the charger's voltage based shutoff timer.
I need to:
  1. check the water levels (I'm embarrassed to say I haven't checked in probably two months); and if that's OK,
  2. swap out those two batteries and see if I can get better performance out of two randomly chosen others that we have sitting on the sidelines.
