Couldn't he just block the secondaries? Or even put a choke-cable block on them, so that when he's just driving around, they're blocked, but when he needs the power, pull the cable and it releases the block... something like that.
JW, cuz alot of the guys that I run with don't use accelerator jets (proper term?) they just use the primary jet in the carb... the other side is blocked off.
