Old 01-30-2008, 10:20 PM   #19 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
tricky part is making the air that you don't block go thur the radiator and not thur the cracks around the radiator, headlight wires, hood release cable, ac lines, bumper mounts, etc... if you just block at rad. it forces air thur the leaks in the chamber that's between the grill and rad., true it also slicks over the grill and diverts air around. Or are we talking directly on the back surface of the grill.
Aluminum tape works good over small holes, I use cable ties and plexiglass or aluminum sheet. I go the local recycler and buy aluminum by the pound out of the their junk pile. I scored a bunch of old road signs the county had scraped. One was so big I made both my side skirts out of it.
Frank Lee,
I am trying to figure out a way adjust the amount of air ducted to the rad. manually from the drivers seat?
