Old 12-01-2008, 09:23 PM   #9 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
It depends on the ECU if it is going to help anything with warmup smoothness. But if you do engine off coasting the 1 wire sensors cool down quick and take a few minutes to warm back up even if the engine is at full temp while driving easy. I would suggest using a 4 wire sensor and running the ground back to the ecu to get a lot more accurate signal. On an OBD1 Metro as soon as the water is over 110 degrees I think, and the sensor is reading the car then starts using it.
4 Wire Oxygen Sensor–MetroXFi.com
lot more info on switching to a 4 wire sensor there.
My Convertible Metro XFI Plug in Hybrid Project build log
