Old 12-02-2008, 11:31 PM   #3 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Hydrogen burns great. The trouble is making it in the first place, and how much energy that takes.
If you are making it on the fly by using electricity generated from your alternator, it is going to take a LOT of energy to make, thus greatly loading down your engine.
In some ways, it's like trying to make a perpetual motion machine.
One way it could work, is to have a supply of charged batteries, which would run the current to make the gas. Charge the batteries at home, and recharge them again right when you get back.
A more efficient way to use that electricity would be just to have it run a motor instead.
A seperately charged hydrogen gas generation system would have the advantage of still being able to cut over to just running on gasoline only. I assume there would have to be some timing changes to make everything run right, so that might be an issue.
A while back, I talked to a really smart guy who has built a slick electric truck, is running a wind generator, and has other smart-guy projects going on. I asked him about hydrogen generation for automotive fuel use. He said he experimented with it and had no luck. I assume he was doing the typical way of running the battery off the alternator to run the H2 generator.
If you try running a system off seperately charged batteries, I would be interested in the results. That's the only way I can really see a workable system.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
