Old 12-03-2008, 01:41 AM   #21 (permalink)
Christ
Moderate your Moderation.
Cara - '00 Caravan Base
90 day: 28.45 mpg (US)
Originally Posted by captainslug View Post
Those are resistor values for 1/4 watt resistors in 820 ohm, 330 ohm, and 270 ohm ratings.
More resistance = less power delivered
I'm not sure what the spec on the LEDs he used are. But should you want to double check his resistor choices you can use an LED calculator.
LED Resistor Calculator
Don't resistors convert electricity into heat?
Isn't that kinda defeating the purpose of the electricity savings from using LED's anyway?
Not being smart here, I'm genuinely asking.
Obviously there is still an economic advantage in never having to change the bulbs again, but damn, it's only a very small amount you're saving, and that's if you changed them ALL on scheduled intervals.
Originally Posted by tasdrouille View Post
Because bean counters always win, that's why.
