Old 12-03-2008, 02:07 AM   #27 (permalink)
Christ
Moderate your Moderation.
Cara - '00 Caravan Base
90 day: 28.45 mpg (US)
Originally Posted by captainslug View Post
The brightest LED Luxeon makes can output 540 lumens at 6.6W (provided you don't have to use a resistor). The resistor used to power the LED from a 12volt supply ends up consuming almost 2 watts.
Could you not use two LED circuits to break the 12v down to 6 and 6?
I can't remember which type of circuit you'd use... I think you'd use two series circuits in parallel.
+ = input
- = output
[-|... = LED's in series
Something like that.. but it's probably wrong.
Originally Posted by tasdrouille View Post
Because bean counters always win, that's why.
