Good news; I was looking at my receipts from the last couple fills and found one with an odo reading. I calculated up thru the current fill using that data to find my last fill mpg . Then I found my 3x5 card with gaslog folded up in some papers in my breifcase . I checked my numbers from the data I calculated earlier and everything agrees.
The bad news is; my mpg fell from mid 70s to 67.91mpg . That's to be expected in a michigan winter. Next tank will be even worse.
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
