Old 12-06-2008, 02:07 AM   #6 (permalink)
Frank Lee
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
If the lube is indeed light enough to evaporate off when the brakes generate some heat upon first use, I can see where that would work.
Right now my truck has axle seal problems and the brake shoes are oil soaked. They still work, just not as good. And when I replace those seals (probably next spring) I plan on hitting those shoes with brake cleaner instead of replacing them.
