Old 12-07-2008, 09:47 PM   #3 (permalink)
gascort
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
Originally Posted by Nevyn View Post
You have the kit version, that came with the display?
Each 'character' is a block of 5x8 pixels. Are the blocks black (ON), and the letters white (OFF); or are they just varying levels of on (one black, and the other blackER)?
Yes, I have the kit, and the included display.
The latter; the background of each 'character' is black, and the text is slightly less black. If it were not lit, I would be able to read the negative image, I think.
I tried with the computer USB again; works just fine.
When plugged into the car, I scrolled through the contrast settings. Every 3rd or 4th time the lcd backlight turned off and I just saw solid dark 'characters' across the screen.
Thank you for the help!
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
