Old 12-07-2008, 11:04 PM   #4 (permalink)
McTimson
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 45.42 mpg (US)
Make sure the voltage regulator is hooked up properly. I had a similar problem, and it turned out to be the voltage regulator wired up backwards. When hooked up to the 5V from the USB, it worked fine, but 12V from the car messed with the voltage too much.
