Old 12-09-2008, 08:43 PM   #11 (permalink)
Xringer
Old Retired R&D Dude
Little Red - '012 Prius c 2 Two
90 day: 26.38 mpg (US)
Transporter - '09 Escape XLS
Originally Posted by JMags View Post
If 24k BTUs is slightly oversized you might go to a 1.5 ton unit then since your only going to use it in milder weather for heating. And cooling is better undersized to remove lots of humidity so even if it doesn't drop the temperature much its comfortable.
The neat thing about inverter technology is it's not just on or off, or a 2 speed blower, it's variable..
Cooling output is variable from 4,000 to 24,200 BTU.
Heating output is variable from 4,400 to 29,000 BTU.
(from the 24,000 BTU model specs).
So, if it's pumping out 25,000 BTU of heat early in the morning,
it might be down to 5,000 BTU by 9 AM..
Cheers,
Rich
