Old 12-12-2008, 03:26 AM   #11 (permalink)
ken102282
Originally Posted by roflwaffle View Post
What kinda voltage sag are you looking at Ben? That's ~29kW peak assuming the batteries stay at 72V, and even w/ losses you should be 25-30hp unless you get some serious drop. Also, Puekert's is probably killing your range since 43kWh of battery should get you a lot farther than 20 miles in a Metro, something that shouldn't be a concern in properly designed LiFePO4s.
i agree with you. In this situation, it should't be a concern in properly designed LiFePO4s.
