Old 12-12-2008, 08:49 AM   #27 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
Originally Posted by DifferentPointofView View Post
engine is made from different materials that resist corrosion and the electronics do the timing stuff. but you loose a lot of mpg's from using E85. they're built to run on gas, but can run on E 85 or anything between. its pretty much a waste.
My thinking is, if you built an engine specifically to run on E85, you could get just as much power and fuel economy as a gasoline engine by using much more compression. E85 can't match the energy density of gasoline, but it's advantage is it's much higher octane rating (104). That's why I don't get the point of flex fuel engines, these two fuels are really apples and oranges.
I had a good link once, gotta find it though.
AFDC Ethanol: E85 Fueling Station Locations
More choices...
