Doing it cheap would require a great deal of electrical engineering experience. Unless of course you were to make a ridiculously simple electric manual transmission shifter device that controlled the contact setup when you changed the gear setting on the transmission.
Basically turning the shifter nob into a 12V toggle switch. With the pedal being the last bridge on the circuits for stage 2 and stage 3.
