Old 12-13-2008, 01:12 AM   #5 (permalink)
SolarStuff2
Safety
Safety probably the biggest concern... You might recall from old news reels that gas used to be stored at gas stations in above ground tanks... but after numerous fires and explosions... they began to bury the tanks... which created new problems with the EPA from leaking tanks. Not sure how much you're thinking of storing... but if it's a 55 gallon drum... and it saves you $2 a gallon, that's roughly a $100 bucks... although in theory in sounds like a good idea... in reality, it's probably not worth the risk.
Alternative Energy
