Old 12-14-2008, 09:42 PM   #18 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I tried this in my civic, but later turned to slip-shifting into and out of gear, rather than using the clutch at all... frankly, I don't feel that the time taken to turn the engine off and restart is really that gainful for me, as it only takes 10-15 seconds for me to go from 60-40, even down slight hills.
I leave the engine idle (it idles lower than normal already, due to my preference), and pull the selector out of gear as I'm letting off the gas. Then, when I want to put it back in gear, I just match my speed with the accelerator, so I don't have to touch the clutch.
It's pretty obvious why I personally don't work out well doing it the other way though, I've hard-taught myself not to use the clutch unless I have to. (Bad knees, less stress if I don't use it.)
By the way, I pop start my car from a stop in my driveway frequently... usually use 3rd gear, sometimes I just lift in 1st though. It only takes a quick slip to start the engine.
