well I usually just try the matching revs thing with the clutch, but unfortunately I have yet to figure out a way for my scanguage to continue reading stats with the engine shut off, so the one I want to measure most, whether you really have to be sitting idle for 3 minutes or more to make it worth shutting your engine off. But either way the clutching differences should certainly help to increase my efficiency, at this point I will be asking around to see what different people think about the wear I would saving the interworkings of my car by driving normal or certain other styles such as slip shifting. At the start of this thread though I was strictly referring to popping the clutch in the getting the car started aspect, because I have not found a way to make that transition smooth at all, what particular tricks are there to make that smooth, or is it pretty much the way it is?
dude, you're going 50 on I-75.
